一个空间绑定多个域名实现自动跳转的几种方法
2010年4月26日 22:59 本文热度 9886
如果只有一个asp空间,而你又想放置多个多个站点,这些代码可以帮到你[br][br]第一个 [br][br]程序代码[br][br]<%[br]if request.servervariables("server_name")="dzhai.com" then[br]response.redirect "williamlong/index.htm"[br]else[br]response.redirect "index2.htm"[br]end if[br]%>[br][br][br][br]第二个[br][br]程序代码[br][br]<%[br]select case request.servervariables("http_host")[br]case "dzhai.com" '1[br]server.transfer("v3.htm")[br]case "6id.net" '2[br]server.transfer("i.htm")[br]case "write100.com" '3[br]server.transfer("write100.htm")[br]...... 继续添加 ......[br]end select[br]%>[br][br][br][br][br]第三个[br][br][br]程序代码[br][br]<%[br]if instr(request.servervariables("server_name"),"dzhai.com")>0 then[br]response.redirect "index.asp"[br]elseif instr(request.servervariables("server_name"),"6id.net")>0 then[br]response.redirect "x/index.asp"[br]elseif instr(request.servervariables("server_name"),"write100.com")>0 then[br]response.redirect "index3.asp"[br]end if[br]%>[br][br][br][br][br]第四个[br][br][br]程序代码[br][br]<%[br]if request.servervariables("server_name")="dzhai.com" then[br]response.redirect "index1.asp"[br]elseif request.servervariables("server_name")="6id.net" then[br]response.redirect "index2.asp"[br]elseif request.servervariables("server_name")="write100.com" then[br]response.redirect "index3.asp"[br]end if[br]%>[br][br][br][br]第五个[br][br][br]程序代码[br][br]<%[br]if request.servervariables("server_name")="dzhai.com" then[br]server.transfer("williamlong.htm")[br]elseif request.servervariables("server_name")="6id.net" then[br]server.transfer("moon.htm")[br]elseif request.servervariables("server_name")="write100.com" then[br]server.transfer("write100.htm")[br]else[br]server.transfer("other.htm")[br]end if[br]%> [br][br][br][br][br][br]这是一段很有用的代码,和绑定多域名的asp代码类似,如果你只有一个php空间,而你又想放置多个多个站点,下面这些代码可以帮到你[br][br]第一个:[br][br][br]程序代码[br][br]if($http_host=="dzhai.com"){[br]header("location: moon.htm");[br]}[br]elseif($http_host=="6id.net"){[br]header("location: williamlong.htm");[br]}[br]else{[br]header("location: other.htm");[br]}[br][br][br][br][br]第二个:[br][br]程序代码[br][br]if($http_host=="dzhai.com"){[br]require "moon.htm";[br]}[br]elseif($http_host=="6id.net"){[br]require "williamlong.htm";[br]}[br]else{[br]require "other.htm";[br]}[br][br][br][br][br]二用js来实现多域名的跳转[br][br][br][br][br][br]详解:[br][br]1:首先,你的空间必须支持asp,并且这个空间可以绑定下面所用到的两个域名,然后新建一个asp[br][br]的首页文件,这个asp文件中的代码这么写: [br]<%if request.servervariables("server_name")="xxxx.cn" then '第一个输入的网址[br]response.redirect "index.html" '将它转发到相应的文件夹[br]else%>[br][br]<%end if%>[br]<%if request.servervariables("server_name")="xxxx.cn" then response.redirect [br][br]"index.html" [br]else%>[br]<%end if%>[br][br]<%if request.servervariables("server_name")="xxxx.cn" then '第二个输入的网址[br]response.redirect "soft/index.html" '将它转发到相应的文件[br][br]夹[br]else%>[br][br]<%end if%>[br][br]<%if request.servervariables("server_name")="xxxx.cn" thenresponse.redirect [br][br]"soft/index.html"[br]else%>[br][br]<%end if%> [br][br]2:写好后将这个文件存储为index.asp ,也就是要做你的首页。不用担心,这个是不会显示的。这[br][br]个就是自动识别访问者输入域名的,然后依据访问者输入的地址进行自动跳转的。跳转是在瞬间完[br][br]成的,你是看不到的。呵呵[br][br]3.现在要做的就是把你空间中建立两个不同的文件夹了,分别做为两个网站的目录。比如一个放音[br][br]乐的cd文件夹。一个放flash动画的flash夹件夹。里面的内容自己放![br]4.开始上传刚才做的index.asp文件吧!把index.asp文件上传到空间根目录下。[br]5.去你的空间中将两个域名都进行绑定好,然后就可以测试了。
该文章在 2010/4/26 22:59:00 编辑过
